Can you ID this carb?
diddy2003
Old Time Jeeper
Western Massachusetts
1984 CJ-7
35x12.5x15 MTRs;
YJ 4 inch Skyjacker lift w/ Bilsteins;
rebuilt AMC 360, Patriot Headers, Holley Truck Avenger 670 CFM, Edelbrock Performer Intake, Flexalite Electric Fan; Griffin Aluminum Radiator, Dual Flowmaster Delta Flow 40s;
Dana 30 4.10s w/ Detroit Truetrac;
Dana 60-2 Narrowed, 11 inch Ford Drum Brakes, 4.10s Power-Lok LSD; NV4500; Dana 300 LoMax 4:1 Twin-Stick; Navajo Power Brake Booster
NV4500 gear ratios
1st gear: 5.61 : 1
2nd gear: 3.04 : 1
3rd gear: 1.67 : 1
4th gear: 1.00 : 1
5th gear (overdrive): 0.75 : 1
Engine speed at 55 mph: 1624 RPM
Engine speed at 65 mph: 1919 RPM
Crawl Ratio: 92 : 1
So I want a MC 2100 for my AMC 258 i6 / 4.2l , but I came across this carb yesterday and wondered if you guys knew anything about it. It was at my friend's house and he didn't know much about it.
Thanks.
I would guess a Rochester 2 barrel, 2GC . They ran on Jeeps 225 Engine from 66-71. Also other GM vehicles. Buicks I think.
Think it would be worth it to rebuild it and run it on my AMC 258 i6 / 4.2l ? I wanted to replace the carter because it doesn't run well on steep wheeling grades. Or should I just save and get the 2100? The only reason I ask is because this one is free.
i would spent the money on a rebuild kit and try it out. its a lot less expensive than a new carb. you never know, it might just work really well. or it could be :dung:, i dont know:confused:
:agree: a rebuild kit is cheap give it a shot.
Thanks. I found this:
Carburetor Info Page
KT-5377 - Carburetors Unlimited
I know that I would want a 1.08 venturi with the 2100 on the AMC 258 i6 / 4.2l . How big is this one? I can't find a venturi size or CFM listed.
Another rebuild kit:
Rochester 2G carburetor rebuild kit BUICK 1977-78 CHEVROLET 1978 OLDSMOBIL
Not a lot of money and it seems complete.
Will this mount right up to my AMC 258 i6 / 4.2l ? I don't know what it came off of and I don't know what that backing plate was for. Where could I get a correct one?
Thanks for the help. Saving money versus buying a new 2100 is a good thing. My carter sucks in the woods, but it is decent on the road. I would like a carb that is good in both places. :chug:
