Carb novice looking for help
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
All the advice is good, but I always wonder when a problem like suddenly pops up. Your problem It could be electrical. Are you running an Electronic ignition? Probably, when ever a vehicle runs worse when it hot I think about electronic parts breaking down with heat. Either the coil or a module.
How cold is it where you are? Cold weather will expose problems you didn't know you had. Water in the fuel system will make trouble like you are experiencing.
