Carbs etc.
Carbs etc.
eatdrinkadam
Seal Beach, CA
1985 Jeep CJ7 4 cyl.
Jeep peeps,
Ive been tossing around the idea of doing an overhaul of my carburetor on a 1985 Jeep CJ7 4 Cyl.
However, my carb is aged and weathered and I though It would be better to purchase a rebuilt carb and have it replaced:
Jeep Carburetor 2.5L CJ5 CJ6 CJ7 Carter Weber 7705-S - eBay (item 290485953625 end time Jan-07-11 15:07:59 PST)
The carb I have now is a Carter YFA single barrel.. model # 7700.. the carb in the link is the same thing, although the model number is 7705. They look identical and the description says it will fit my model of Jeep.
Do you think there will be any difference?
If you drive it every day I would say buy the re built but if you have other transport I would buy the $15 kit and give it a try. You will need a couple of other things as well.
What do you have to loose?? rebuilding a carb is fun and when you have done it successfully it's something to feel proud of.:cool:
I drive it occasionally.. However, the Jeep is in very nice condition, and I'd like to replace the carb for longevity & value as well.
IO makes a good point. For the $20 or so for a rebuild kit you still have the stock oem carburetor and you did the work to it. It's really not that difficult to do and as long as you take your time and lay everything out nice and neatly and follow the direction.
Ok, so tried adjusting this screw back up and didn't make a difference. I guess I'm looking for other opinions what could be causing this. Also, once in a while while running down the road the trottle gets "unstuck" or allows a full throttle movement as it's suppose to.
Hey did you ever get your Carb figured out? I've had so much trouble with mine running super rich! I also have a '85 with the 2.5l engine. I'm having a heck of a time getting it set? first I messed up the float setting fixed that, had replaced the "O" ring on the needle valve then it was running good but with a rough idle. I messed with the air/fuel needle again and totally screwed it up again, its running so rich I cant drive it. some one replaced the carb with a rebuild in 2009 so I figured it can't be that bad. Was wondering if you had found any tricks on tuning yours?
