Carburator question
Been watching youtube. Saw the Ericthecarguy video and others. Now I'm beginning to fell like I'm getting into the swing of this. Lumpy and others are right, all of the videos say to START with a adjustment of 2.5 turns. One even said that 2.5 turns was a factory setting. Since mine is at ~1 turn she most certainly is too lean to start with. This gives me an excuse to get a vacuum gauge so I believe I will.
Lumpy, the video guys say that you actually don't need to move each at the same time which is good because the drivers side screw with all the vacuum, water hoses, Air pump hoses and spark plug wires in the way is a bear to get to. I only want to deal with it once or so. It looks simple enough.
Warm engine up, now that I have a proper starting place it will be easier.
Install gauge to a vacuum port.
Turn the needle adjustment in or out until the rpm's are at the max ... they will start to fall when the adjustment is to far.
Reset the Idle speed and do the other needle the same way.
Adjust the idle speed and hit the road.
There was no mention of energizing a solenoid, where ever that little devil is.
)has far more wells in operation than in Southern Ca.
