Chevy305/700r4tran?
Cheepjeep85
Crazy Sr. Respected Jeeper
- Media
- 57
- Chickamauga, Ga
- 1985 Jeep CJ7, 258, t-176, D300, AMC20, D30
Dang fifesjeep your brutal. It' seems your the only one who doesn't understand that when youve(meaning me) never done a build like this, things will change. It's getting an idea researching it, throwing it out to you guys to get feed back. Questions are then raised, opinions are given. Then you'll need to research those questions and opinions, and yes things do change. Sorry you seem to be so bothered with this. I'm doing my best not to waste Anyones time. This is a forum for discussion and opinions that's why I'm here.
No matter how you build it, your probally going to change something down the road.
It's a jeep thing.![]()
No, I'm not being brutal... I just don't see or foresee any progress for a hot minute. As far as me not knowing or understanding what it's like to have a first build is...Dang fifesjeep your brutal. It' seems your the only one who doesn't understand that when youve(meaning me) never done a build like this, things will change. It's getting an idea researching it, throwing it out to you guys to get feed back. Questions are then raised, opinions are given. Then you'll need to research those questions and opinions, and yes things do change. Sorry you seem to be so bothered with this. I'm doing my best not to waste Anyones time. This is a forum for discussion and opinions that's why I'm here.
Why an old school TH350 ? With any type of decent axle gearing. The final drive of 1 to 1 the T350 has. Limits on road flexibility. Especially taking into account what Dano`s intended use is.No, I'm not being brutal... I just don't see or foresee any progress for a hot minute. As far as me not knowing or understanding what it's like to have a first build is.... We all have stated, gave ideas, opinions etc from experience etc... Between the two common swaps (Ford & Chevy) both are covered extensively on most Jeep forums. I'm just saying keep it simple... You already know how you are going to use the Jeep, mostly road use with light offroading from time to time. This is my advice for you to start with... D44 front, Go with the 8.8 rear, Chevy 350, if you want an auto go with the TH350... If you use a driver drop front axle I have a TH350 to Ford T-case adapter
.... if you want to use a manual tranny go with a 5 speed because this Jeep will be on the road more than the trails. The NV4500 is a great option especially when you toss on a D300. The biggest thing in my opinion is knowing how you are going to use it, once you know how you are going to use it, build it to be stronger... with that you can't go wrong.
Ain't that the absolute truth!![]()
Much rather see an overdrive a 4 speed automatic or a 5 speed manual. .
I said the TH350 for a few reasons... and here are my thoughts as to why. His rig will be on the road 80% of the time and he's going to want highway gears... and to me, those are 3.54's or numerically lower. If I recall correctly he won't be on the rocks but more or less on wet/slick trails/hills etc so tire speed will be essential. My other thought for leaning towards the TH350 is that it's one of the smaller/shorter/durable auto's out there which will allow a slightly longer DS length when compared to other auto's.
As for Manuals... I'm all about granny 4 speeds or if one can find a 5 speed that the price isn't through the roof then I am all about that... I've been wanting a 5 speed manual...![]()
Not if he is going to run any decent size tire. Unless Dano goes to an Atlas 4 speed TC.
My NV4500 came fron eBay. At the time it was only a few hundred bucks. Bet you could still find one if you looked hard enough.
I've been looking on cl everyday for a motor and trans no luck yet but I'm trying to stay optimistic. As for the usage of my jeep, when I said 80% on road and 20% off I meant that because of how much I work getting to a trail will only happen when I get time. The jeep is not a daily driver so I still want to build a jeep more for off roading. I probably won't be on the highway much. So realistically I would use it 80/20 but still would build it 50/50 usage. On road to off road. Sorry for any confussion. Isn't the nv4500 a 200lb trans? Pretty heavy compared to the th700 trans. Does the toughness of the 4500 make the weight worth it if I can find it?
