CJ4A leak in transfer case shaft
asdex
New Zealand
1978 Mahindra CJ4A.
You should be able to put some ultra black oil resistant silicone on the bolt threads. The intermediate shaft is a fairly tight fit with o-rings on the shaft so it won't fall out on you. The bolt holds the shaft retainer in place.
CJ4a ? There was only one prototype CJ4 ever built, flat fender or rounded?
Anyway that is the keeper for the intermediate shaft that is full of bearings and gears so I'm glad you did'nt try to pull it out. you can take the keeper bolt out with no worry though.
I think the Mihindra CJ4A was the knock off of the Jeep CJ3b .
Thanks, That makes sence.
