CJ7 Dana 30 with drums spindle bearing kit
moriartii
Leander, Tx
'76 CJ7, AMC 360, TH400, Quadratrac, D30, AMC 20, Edlebrock intake, Holly 4bbl carb, 33inch tires
Does anyone know the proper spindle bearing kit for a 76 CJ7 with a Dana 30 and drum brakes?
So far I have picked up Napa BK1 and I have picked up Dana Spicer 706527x.
The Dana Spicer part was check via Rock Auto and via Danaaftermarket. The issue I am having is the spindle bearings appear to fit but the thrust washer, slinger and k seal are a tad too big.
Upon disassembly I notices the k seals were missing and the long axle shaft is all corroded.
Lee
looking up the N.A.P.A. website, there seems to be other p/ns for that application, like bk1, bk2, bk3, bk4, and bk6. There was a difference in the spindles when disk brakes were added as the disk brake version was stronger and I have heard of the drum brake version breaking. I would suggest taking the spindle back to N.A.P.A. if you could.
Torx-
I dont have a spindle from Napa, the spindles are my originals, I am trying to track down the correct spindle bearing kit that has the outer axle slinger and K seal that fits correctly; so far they have been a bit too big.
Lee
Let me clarify what I am trying to say. When I looked at the N.A.P.A. website, there was 5 spindle kits listed for your CJ, at least that's what I saw. You could have got a kit for the disk brake spindle which AMC converted to at the end of '76, or at least from what I have read. You might just want to take your spindle in to find a kit that will fit.
Yeah I see what you are saying now, not sure why I did not pick up on it before. :)
So I think you are correct in that the kits I am getting are for disk which would make sense since the spindles are larger and I assume the axle stub is too.
After finding the Dana 44 67_78 it appears I actually need a seal that looks like a wheel bearing one versus the K seal. The nice part is the kit I got from Denny's Driveshaft has the bearing and the v seal I need. Just need to source the oil seal.
Lee
TCase Dana 20
$35.00
  17.5%
