Clutch fan or electric?
- Media
- 186
- Resources
- 1
- Plumas Lake, CA, USA
- 1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
Well... Was doing a little wheelin and mudding this last weekend, everything going fine, then put the fan through the radiator...
Apparently when it hit the muddy water the flexfan bent a blade and hit the radiator which, it seems, blew the bottom seal on my radiator, and smacked up the inner "face" of it...
Know i need to check motor mounts, what else?
And while fixing, electric or clutch? Whats the pros /cons?
