Clutch options
Clutch options
Can you not reuse flywheel bolts?
I have always reused then and always resurface the flywheel.
Cool. No luck at Napa or O'rileys. Going to order from Summit and it should be here Wed for a LUK. [emoji1303]
Not really supposed to, as they are 'stressed' from the torque setting.
That said-I have done such so many times, and never had an issue.
You will need a torque wrench for the reinstall. Couple drops of red locktite on each bolt, wouldn't hurt either.
If it's a 76-79 CJ T18 (~7" - 7.5" input shaft) then it's a 1-1/16 input shaft. Luk 01-015 is what I used for mine. Only a couple hundred miles so far but I'm pleased with it.
I think the 72-75 CJ T18 (these are 4:1 1st gear and have an adapter between the trans and bellhousing) are 1-1/8" input shaft.
Are you talking about the 2 shift rods being different lengths? That's fine and just how they are.
If you're talking about the tube for the shifter pivot and the linkage, the T18 uses longer linkage and tube than the T150. You'll need to use the T18 linkage and tube with which ever tcase you use.
I had no idea those linkages slid out. I figured that part out. I'm going to send you a PM and ask you something.
