Crazy transmision
Crazy transmision
tyler m
palmdale,california
i have a 1969 cj-5 i think, with a f 134 hurricane four cylinder motor,im not sure wat kinda of tran and transfer case all i know is that i have 4 stick levers
OK well i have a 1969 CJ5 and i have no clue wat kind of transmision i have.. all i can say is that i have four stick levers..
1. is a three speed
2. is a high and low
3. im not sure wat its for may have to do with the 4wd
4.seems to be a granny granny gear
does anyone know wat i have and if it is stock or not... please help
Photos would help.
could be a T-98 ? (early version of a T-18 ) ganny first gear
I think you have a T-90 three speed Transmission . That's what was used in with the F134 Hurricane engine.
Your TCase is a Dana 18. It has 2 levers. One to engage the front axle. That one turns on the four wheel drive. The 2nd shift lever on the TCase is for low range.
Oh one last thing: if you have a 3 speed it isn't granny low. It may seem like it because the axle gears in those old CJ5 's are very low.
EDIT: I just re-read your post. The 4th lever is for the Overdrive .
    Best for votes
    on specific items
