D30 passenger seal leak.
Dan77CJ7
Denver,303Local
76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
^^ what he said ^^
I use a long 1/2" drive extension and a big socket.
Now would be a good time to change the spindle bearings and seals also.
Yes would also change that seal, and anything else I could while I had it all apart.
Yes get the 4 piece spindle set, bearing, seal, washer & seal. And check all mating surfaces for seal wear, and wheel bearing & hubs.
1/2" dia. pipe and a lg washer works well for Dana 30 axle seal install.
Old dog you make a good point, Thinking that the shafts could use a rebuild. spicers? 5-260x? or does anyone know of a better U-joint? :chug:
You can get some CTR rebuildable.
**CHEAP LOCKER**
What do you guys thing about the aussie locker? Im going to assume when i pop the diff, a spring from the quick lock should end up in the catch pan.. I need this Dana 30 rebuild to hold me over untell I hunt down the right T-18a....:mad:
Designed by Bill Cole who also made the Chevy Small Block.
All I have heard is good things about it so far, but time will tell.
Not a rebuild a reseal.
Axle and caliper are being rebuilt... new wheeling bearing,spindle bearing, synergy ball joints new locker(undecided) along with all the seals.... this friend is rebuild in my parts. :cool:
Also thinking about hubs.. I have cutlus hubs now, and they work perfect, and i like the vintage look.:chug:
Axle and caliper are being rebuilt... new wheeling bearing,spindle bearings, synergy ball joints new locker(undecided) along with all the seals.... this here friend is rebuild in my parts. :cool:
Also thinking about hubs.. I have cutlus hubs(maybe stock???) , and they work perfect, but I havent found any parts or prints on them.
Sure like my Mile Marker hubs with run'n a DL up front.
If i could get a No-spin i would LG, But i dont see my self getting Crmo Axles and i hate to bust U-joints, Not that im saying you need Crmo axles, they tend to flex less at the eyelets. "A broken U-joint trail story...." Reason number 4 why I'll only roll on 32s
Nice,
Stock was a drive flange or Warn. Cutlass is real strong, and easy to turn in & out.
$45.00
  22.5%
