Dana 20 shift linkage issues.
FarmerRoger
Always had an issue shifting the Dana 20 on my 73 CJ5 .
Understand the vehicle needs to be rolled slightly to shift the TC.
It has a single shift lever, with one three hole bell crank.
The center hole connects the link from the shift lever
The two outside holes connect links to the two D20 shift rods.
Earlier models incorporated two shift levers.
Looking for the shift rod positions for
4H, 2H, Neutral, 4L
If each shift rod has two positions, then four combinations of shift rod positions are available.
The outside shift rod has a link between it & the bell crank , while the inside shift rod is directly connected to the three hole bell crank.
Basically , want to understand the mechanics of the linkage.
4H, 2H, Neutral, 4L
