dana -20
do es this transfer case use poppet ball & springs for 4 wheel drive shift levers ?? The ones I ve seen have plastic caps in holes?
:)Yes, The Dana 18 and the Dana 20 take a poppet ball & spring to detent the shifting rods...........a set screw or bolt holds them in place.
:D:D:D:D
The plastic plugs are acess holes to drop the ball and spring in, push them down and the shift rod actually hols them in. The plastic plugs can have a ball switch for a four wheel drive light on the dash. :D
The springs can collapse or get sticky.
TCase Dana 20
