dana 44 1970, can i upgrade the brakes?
buzzinhalfdoz
east tn
1970 cj5 134-4cyl (tub off frame and back on, suspension done(2.5 " yj spring lift),assembling engine now) after engine goes in steering upgrade to saganaw.
just tore down my Dana 44 rear to put in a posi carrier and rebuild brakes. can i put modern style shoe retainers and self adj hardware instead of the original?
ps i have worked on cars since 1976 and i have never seen this type of brake hardware.
does anybody know where to buy a stock or aftermarket brake hardware kit???
1970 CJ5 10" drums
If your brakes have the automatic rod type adjusting rods, no source new that I know of.
Have you considered replacing 10" brakes with Bendix 11" drum brakes?
Easy bolt on, more modern cable self adjusters.
I put GM disc on mine
look up HERM THE Overdrive GUY
he sells kits for it
he is on our links page
what do i look for to rob the 11" system off of, or is it available after market?
TCase Dana 20
