Dana 44 rear disc brakes
LASTCJ786
Mass
86 CJ7 258, T18, Scout 300,twinstick ,Dana 44 front locker, Dana 44 rear locker 3:73's,4"lift ,1" body. 35" tires,York OBA,Warn 8274,Fullcage.
Who makes the best Dana 44 rear disc brake kit?
I've got one of the last CJ7 's a true 86 with the factory Dana 44 .
I have a couple of those late 86 44s and several Model 20s, whats funny is that they use the same brake parts as the 20. Even the backing plae is the same except for the hole is larger to pass over the bearing and the 4 bolt holes are larger. I would really think (based on my comparison) that a model 20 kit could be used on a late CJ 44 with a little mod work. The main show stopper would be the bracket that bolts to the tube flange would need to be larger to fit the thinker tube and larger bolt patter.
Here's alink that I found for one of the few companies that has one just for the late 86 CJ 44...
CJ-7 '86-'87 Dana 44
I think I'm going with ZJ rear disc's 93-98 I will have to do some redrilling but will have a parking brake.
I still have not done the rear disc brake sawp yet I'm now looking at the Ford 8.8 becouse the mouting holes are real close to that of the Dana 44 .
It's called kunifer (copper/nickel mix) and its what we use in Europe as the steel lines rust because of the salt and grit placed on the roads in winter. It's a lot easier to work with and flare.
Nice write up. Thanks!
:D
TCase Dana 20
$35.00
  17.5%
