Distributor Help
Distributor Help
SlayerBLS
Houston
Use the search function on here. There should be a write up by someone like teamrush. To answer your question: Yes it can be done.
Then you can ship the points dist to me, i'm in the market for one.;)
What engine do you have?
The HEI ignition is self contained and easy to install. You mainly need to get 12 volts to the coil on the top of the distributor. You will also need new plug wires. Check out this link:Installing HEI Distributor Jeep CJ-7 AMC 360 V8
BTW all AMC V8 engines are the same so this link also applies to the AMC 304
fill in your stats so we know you have.
Hey Busadave 9 thanks that is a big help. I am not sure what HEI i got the PO already had it bought and I cant tell from the box. I need to look up the company and cross it with the part# I will also post a pic of it tonight to see if someone can tell me what I have. Once again thanks I was about to chicken out of doing this but this seems to make it sound not to bad.
