Dizzy mods. Changing the advance curve.
fzsk4p
Michigan
Ground up YJ.
Looking to get a CJ
Good info John.
With my propane conversion, I am going to do some research on this more in depth as the LPG is a different animal with timing. Wondering what changes I should make for optimal performance.
Good info John.
Jim, you should be able to crank a bunch more timing in. Intial, advance and total.
~Pane has a lower BTU quotient. Increasing timing will increase cylinder pressure without as much worry of detonation or pre-ignition. Somewhat off-setting the BTU phenomena.
    Best for votes
    on specific items
