drifting timing (caution VERY long winded!)
It's just the air cleaner - a four-barrel works just fine with power brakes as long as you use a skinny air cleaner or one that hangs off the side. The 4v carburetors have nearly exactly the same footprint as the 2v carburetors do.
Of the carburetors you've listed... I like the Motorcraft, the Holley, and the Weber. Dunno squat about the Barry Grant.
BG is a Holley copy.;)
It could be even cheaper, I picked up a tbi from a 4.3 blazer off CL for $200, got everything, throtle body, wireing harness, sencers,and even the steering colum. The 4.3 was running but had a bad rod knock so I know everything works.
I just picked it up for extra parts. But I did have to pull it myself, but at least I know what I got.
thats a good find, i hoping to run across a setup like that, might even get one free i have alot of friends that mess with s-10's and other lowriders, i used to have a 99 xtreme with 4.3 dropped on 18's, shaved door handles, shaved bed seems, and other assorted shaved stuff on the body i was gonna put airbags on it but never finished it, sold it to fix up the jeep $3,500 minus paying a few bills, got the CJ7 back on the road and in driveable condition
Well with some hesitation I decided to read this thread from the beginning and now at 90+ days with some "weather related delays" Elwood still does not heve this thing running right? There has been some very good sugestions in between the static and if he would just get back in the garage and get this done(no more carb. toss either) I think there's gona be alot of celebration.:chug:
Did not seem to get any aplause but I want to try the top dead center in one direction then rotate the reverse while watching dist. to check your timming chain slack trick, now that's smart!
the timing chain trick wouldn't work so good if your distributor gear was wore out like mine was on the factory dist.
True, but I still liked the idea.
VICTORY IS MINE!!!!!!
I will no longer allow myself to be humiliated and discgraced by an inanimate antique machine. I am victorious. I may have lost many of the battles, but the war is mine :laugh:
I ended up buying another Autolite/Motorcraft 2100 series carburetor online. Found a guy from upstate NY that rebuilds them. I bought a 1.14 venturi size (roughly 300cfm) 2100 originally off of a 1965 289. Less than $AMC 150 shipped, still A LOT cheaper than a Weber, a Holley or a Barry Grant. I ended up putting in a different power valve, because I learned that a power valve should be approx 1/2 of manifold vacuum. I pull 17lb of Hg at idle, timing set at 10 degree BTDC. The new carb had a 6.5hg power valve in it, I switched it to a 8.5. I also downsized the jets from 50's to 48's, but the 50's may go back in.
A very, very sincere thank you to everyone who has kicked in ideas, thoughts, oh by the ways and the occassional dose of bs (even if I did deserve it) :chug:
I ended up buying another Autolite/Motorcraft 2100 series carburetor online. Found a guy from upstate NY that rebuilds them. I bought a 1.14 venturi size (roughly 300cfm) 2100 originally off of a 1965 289. Less than $150 shipped, still A LOT cheaper than a Weber, a Holley or a Barry Grant. I ended up putting in a different power valve, because I learned that a power valve should be approx 1/2 of manifold vacuum. I pull 17lb of Hg at idle, timing set at 10 degree BTDC. The new carb had a 6.5hg power valve in it, I switched it to a 8.5. I also downsized the jets from 50's to 48's, but the 50's may go back in.
Let me be the first to congratulate you on your accomplishment.:chug:
To sum up; you replaced the carb with an almost identicle carb. Care to venture a guess what the problem with the old carb was/is??
remember; all glory is fleeting.
:dbanana: Good for you, just in time for summer.:chug:
I'll buy the first round!
Heck, I BOUGHT the first round - it's sitting on the desk in front of me right now... :)
