Driveline down angle
mriplaybass
Full Time Jeeper
Featured
Wisconsin
1979 CJ7 304 T18 w/6.32 lo d20 w/3.15 TeraLo D44 rear & D30 Front w/4.56 Eaton Elockers front and rear,
1959 CJ5,
1954 CJ3B,
1967 CJ5,
1947 IHC KB1,
1947 IHC KB2,
1947 IHC KS5,
1967 Mustang Coupe,
Our 2 week spring Jeep project has, as usual, turned into a 2 months and counting project.
As I have stated in our build thread, we are changing the T-18 long shaft that came out of a J truck, to the short shaft T-18 that belongs in the Jeep. This means that we will need different drive shafts, and will have to install pinion angle shims backwards to achieve proper driveshaft slope. So I have been thinking, since I have to make a new crossmember, I might as well make it to provide maximum belly clearance. Previously, the driveline down angle was around 6 degrees. I am thinking of raising the back of the Transfer Case so that the driveline down angle is around 2 or 3 degrees down. That will give me an additional 1 to 2 inches of clearance.
Opinions? Pros / Cons?
I don't really see any problems doing this since our CJ's are on much greater angles up and down when we are off road with them.
I dont see a problem with it as long as your pinion angles are good. I shoved my NV4500 as far up as I could into my tub and will have 3 inch drop belly pan on mine.
