Drive shaft angle
Drive shaft angle
bbbobbb
perkasie
1984 CJ7 258, Dana 30 & 44,
What would be the max safe rear drive shaft angle I can run
Here’s what has worked for me. U-joints can tolerate as much as 8 degrees of an angle, as long as the other u-joint is opposed by the same angle. However, you might experience vibrations if the difference of these two angles is more than 3 degrees. Other factors like shaft length, suspension travel, or axle wrap might have to be considered. Good luck.
