Driveline popping/binding sound with video
jwnaron
- Denver, CO
- 1979 CJ7 orange, white hardtop, Levi's blue interior, 258 converted to fuel injection,THM400 with "SHIFT" shift kit, Quadratrac TC converted to part-time, warn premium manual hubs, D30 front welded/AMC20 welded rear axle solid piece rear axle, G2 30 spline axle hafts, ARB lockers Front/Rear, High Output ARB on-board air, TR HD Beadlocks, 35" Maxxis Creep Crawlers, Poison Spyder front bumper; Rock Hard 4x4 Rear bumper w/ tire carrier, can mounts and rock cage.
I can certainly try that, if I can find something the right diameter. That snap ring is about 3 inches in diameter. I was pretty spent when I tried it last. You know a nights sleep can sometimes fix problems. I haven't tried it since then. I'll let you know.
that follows I'm back on it! I ended picking up a set of craftsman "multi use sockets" and the 3/4" size with a long extension took it right off. yes, I actually drove down to the local sears and bought it, after calling several local shops asking for recommendations on where to find a pipe plug socket.
The underside was very clean too.
When you start your build thread you'll need pictures of the inside and of the motor too. Good luck, you can feel proud that you've crossed a few big hurdles already.
