Misc E-Brake Cable Floor Hole?
TedGros
Lake Havasu City, AZ
‘78 CJ7, 304ci, 3spd Dana 20,
I replaced the floor pans on my 78 CJ7 build and there is no hole punched or marked for the e-brake cable to pass through. Can anyone give me the (approximate) measurements from the left side and firewall as well as the diameter of hole to drill? Also what grommet is right or best to use to protect the cable? Thanks.
Solution
Here's a few shots of mine. Floor has never been replaced. Here's the cable itself, then a tape measure showing 3 inches from the left side to the center of the hole, then another showing 1 inch down from the firewall/floor seam to the center of the hole.
As for the grommet, the factory part # J5351742.
Here's a pricey OEM replacement: eBay Link
Solution
Outstanding! Thank you. I would have certainly drilled it wrong.
As long as you're close your fine. It has adjustment
I suppose you’re right, but my OCD would remind me every time I looked at it. Lol
I get it but after a while I just don't give a rats A**
$20.00
  10.0%
