Electrical & Vac Line Streamlining Help?
cj4dummyz
Connecticut
Present: Jeep Grand Cherokee Laredo 6 cyl daily driver, 1982 CJ-7 rebuild in progress. 258, I6, 4.2, Wide Track, 4" suspension, HD steering, one piece rear axles, rear disc conversion (Nissan/Suzuki), etc. Harley XL1200C 50th anniversary.
That "Mystery Box" is the ignition control module that works with the Ford Motorcraft distributor in your CJ. That distributor with the "Team Rush" upgrade will work as good as a hei distributor will. The hei has its ignition module inside its distributor. If you remove all of the emissions equipment from your vehicle a lot of those wires and vacumn lines can go with them. There is also a computer behind the glove box which will also not be needed with the Nutter By-pass. Good luck with converting all that highly engineered and complex equipment into something you can work with.
Thanks, I appreciate the help. One concern I have though, is that the weber k551 has an electric choke. The wire in the old carter ran to a choke solenoid and switch, which I'm assuming tied into that whole feedback mess that I'm trying to get rid of. Can I just wire the electric choke straight to the kwik wire harness and be done with it? Or do I need the solenoid and switch for the choke that are shown in the factory wiring diagrams??
I think that mystery box is not the icm, but something else. Usually the icm is located on the drivers side fenderwell under the coolant overflow bottle. I can't give you an answer on your electric choke with that kwik wire harness, but maybe you could run something with a manually operated electrical switch?
Thanks alot for that suggestion. Started thinkin about how I start my Harley and what you said makes good sense. Take the electricity out of the equation alltogether. After a little further research, I Found a nice looking manual choke conversion for the weber k551 on piercemanifolds.com for about $60. The universal ones are cheaper (around $20), but I think I'll go with quality. Thanks again.
Webber carb, HEI and junk all the computer/ignition mudule :dung:. For the electric choke you want to run a relay to activate it. Get the switch power from the exciter wire off the altenator this way it is only heated why the jeep is running. If you wire it off any other 12v ignition hot soure when you turn the key on it will automaticly start to heat up. So if your listening to the radio with out the jeep running the choke will eventually go full open and be a PITA to start. IF you dont know how to run a relay they are very easy. Google it.. or let me know and I can give you some better instructions.
My YJ.. Same motor and electronics as a CJ.. has 3 vac lines and 5 wires going to the motor including the sending units for the gauges.
Awesome. That's the kind of answer I was looking for. Do you have a pic of your engine compartment you could post? That would pretty much solve all my problems. That or diagrams you have used would be good. Thanks.
You in luck.. I just wrapped up some wires with loom and took a few pics.. I've done a. It of electrical work in the past so I go mostly by memory for diagrams. When I get a chance ill post a few pics.
Oh I am using a 21 circuit ez wire kit. Paid $175 shipped off ebay Like a painless kit ez wire is marked every 5-6 inches with where the wire goes, has a decent instrction book but does not come with all the ends pre terminated.. I like to do custom wiring and add things in so I would have to hack up the painless kit. And EZ is 1/3 the price. A 18 circuit kit would have been just fine, I actually have to many wires.
I know it's been a while... I took a few months to wrap up all of the body work before I dig into the wiring etc. So now it's time! I'm going to try your advice and do what you said I should do. Just one more thing... I live in Connecticut, so I want to keep the heat for the winter. Can I still use my heater setup if I connect the hoses coming into the firewall? And what would the changes in wiring or hoses be if any? If you have the answer, Thanks!
$45.00
  22.5%
