engine cutting out
koeneke2005
I have a 1979 CJ5 with a AMC 258 i6 / 4.2l and carter carb. The engine Idles fine but when I accelerate the engine starts to cut out and will die unless I let off the gas. If I put my hand over the carb and choke off the air it will rev up just fine. If I remove my hand and rev it up it cuts out again. It will slowly rev up just fine. It only cuts out when the engine is under a load or fast acceleration. Any ideas?
