Engine Engine locked up
mystikdan
Michigan
CJ5, CJ8
Very nice. Looks like it is in very good condition.
Not going to hurt anything putting Mystery Oil or other lubricant into the cylinders and leave them to soak for days or even a week. You can also put the breaker bar on the crank and leave a large weight hanging while it soaks to exert constant pressure on it. Worst case, pull the cylinder head and use a wooden block and large hammer to try and force the pistons down one at a time.
That's an MB from WW2. It has the 134 L134 "Go Devil" in it
I prefer kroil for freeing up the cylinders
I freed a 134 using a 50/50 mix of diesel and ATF. Let it soak for four or five days topping it off every day. Then try rocking it "easy" in second gear. It should free up, if it doesn't continue soaking for a couple more days. Let us know how you make out. I hope this helps.
I picked up a battery and kroil today. I won't get over there till this weekend. Hopefully there's a resurrection on Easter Sunday
Don't be afraid to use a lot. Once it's freed up and you get it running don't be alarmed by the amount of smoke. Kroil or anything else you put in the cylinder will burn off and it smoke like the Dickens.
On a separate note be sure to double check the electrical system they were 6 volt not 12 like modern day. If you try to use a new battery or a jump box you could damage things
What about the fuel system? Is this a cam-driven fuel pump? How likely is it that I can get away with some sea foam and new gas? Is there such a thing as a temporary 1 gal plastic tank or something?
8V battery was in there before, I replaced it with the same
From your picture, some time in it's Past, someone put a 8 Volt Battery in. (It has 4 caps)
Now, if it was done correctly, they turned the Voltage Regulator UP!
The Dash only has a Amp Meter.
When you get it running, check the Voltage slightly above Idle.
Charging it will be 9-10 volts.
ALSO, It is a Negative Ground System!! Which was unusual for 6 volt systems back then.
Good Luck, it should Break Free.
Unless Water was allowed to freely enter the carburetor, it should only be some surface rust. Check for other things that could be holding the Drive Line up. Have some one step on the clutch while you try to turn the engine over.
standard World War II-era vehicles, including the Willys MB and Ford GPW (collectively known as G-503 Jeeps), were designed with a 6-volt positive ground electrical system.
Positive Ground System: In these vehicles, the positive battery terminal is connected to the frame and engine block, while the negative terminal supplies power to the starter and electrical components.
Context: It was common for American vehicles of that era to use 6-volt positive ground systems.
Conversion: Many enthusiasts today convert these vehicles to 12-volt negative ground for better reliability and ease of installing modern accessories, but they were manufactured as positive ground.
