Engine starts then dies
alaskaviper
- Watertown, NY
- 83 CJ-7, 6 cyl. with Howell TBI kit, TF 727 transmission Dana 300 twin stick, 2.5" suspension, 1" body lift, currently under repairs,
99 TJ, 6 cyl., 4" suspension lift on 33s
I just had my engine rebuilt and have the howell TBI installed. It is the AMC 258 i6 / 4.2l 4.2L with DUI and TBI. I have almost 100 miles on the engine since the rebuild. So yesterday I pulled into the drive way to check the fluids and it just died on me. I thought I was out of gas cause I knew I was close to empty. I got five gallons and put it in. Then I tried to start it and it would crank but not turn over. After several tries it would turn over and then die. If I give it gas and hold it at 2000 RPM then it will run for about 10 seconds then dies. I'm getting fuel and have spark. Nothing has changed since i been running it. The distributer is tight so that didn't move. I checked the ground for the computer and they are all tight. The grounds are not painted or rusted. I was thinking fuel pump but now that I can get it to start for a few seconds, I'm not so sure.
I am open to suggestions on what it might be.
And to and to the pain. I got in my TJ to go get gas and ran over a bolt which gave me a flat tire. And somebody stole the bag out of my glovebox that has the lug nut lock key for the spear tire. So I cant change the tire until I get to O'riely to get another key. BAD WEEKEND.
