Engine Engine stumbles. Distributor?
b3uhbp
Arlington, TX
84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
My AMC 258 i6 / 4.2l stumbles on acceleration and begins to knock when under a load. The carb (a Weber 32/36) has been rebuilt, new spark plugs, new fuel filter, new fuel pressure regulator, new vacuum advance. Any idea what it might be? I’m thinking it may be the distributor, a DUI HEI. HELP!
I have the same motor and carb setup on my 81. There is no fuel pressure regulator with that set up. The fuel return line from the carb naturally regulates fuel pressure at least it does on mine with the stock manual fuel pump. Are you running an electric fuel pump?
The only time mine stutters is when it's cold and disengage the manual choke too soon.
Sent from my SM-A528B using Tapatalk
An HEI is a lot better than a stock distributor but the fact that yours spark knocks under load means that an adjustment is in order and will help.
What he said👆 While there could be other issues (lean mixture, plugs/wires, etc), knocking under load usually means too much advance.
The timing was just checked and set but didn’t help. That’s why I think it’s the distributor.
I really believe that who ever did the adjusting must have messed up. If it was adjusted right and there was something wrong in the distributor, It wouldn't spark knock. It would just be lacking in power. It sounds like you have your heart on getting a new distributor any way, And I don't blame you. The OE was junk when new. So go with an HEI that's all set up for a jeep. Their cheap now days and work great.
Make sure the vacuum advance is on the correct vacuum port. The correct port draws from above the throttle plate so it should have no vacuum with the throttle closed at idle and increase as the throttle opens. if it is drawing straight manifold vacuum it will have too much advance. Also if your vacuum advance has a hex shape on the front of it then it is an adjustable vacuum advance. Find a hex wrench to fit down the nipple into the adjustment screw. Count the turns to go from stop to stop on the adjustment, then set it in the middle and tune from there. Base timing should be 8 degrees before TDC. With the HEI you can also use a weight and spring kit to slow the mechanical advance if the distributor uses gm parts. My junkyard chevy 4.1 big cap HEI with AMC V8 distributor gear has worked great for many years. The DUI should run well with that carb.
There is a lot to be said for resetting timing until it wont ping under a heavy load on a hot day. specs be dammed. Saw that in 4wheeler in the 80s talking about IHC 392 V8 engine's ( I had one in a 3/4 ton 4wd truck) . That beast of a gas engine would pull like a 460 ford. MPG was laughable at best towing.
Great info. I’ll check it all out. Thanks
Find another mechanic or learn to rebuild the carb yourownself
Very helpful.
Actually rebuilding a Weber 32/36 is not super hard. You can get the complete rebuild kit from Redline and as long as you have a workbench and a standard toolbox it's easily doable. The instructions with the kit are pretty clear. The super fun part I found was adjusting it for good idle after the rebuild, rebuilding itself was straightforward
I rebuilt mine and hadn't touched a carb other than a lawnmower carb in over 20 years.
Redline is the only authorized Weber dealer in the US. If you are not sure what you need just contact them their techs are pretty helpful. http://www.redlineweber.com/
$35.00
  17.5%
