F-134 Water Pump Problem...
dbcallaw
Chico, Ca
75 CJ5, 350/SM465, YJ spring swap, unknown lift height, stock axles, 33x12.5r15
Hi all,
Just picked up my first Jeep. Its a 1956 with the wicked little F-134 and it needs a new water pump. The engine has dual pulleys on the alternator, crank, and original water pump. I purchased a single pulley water pump, and the pulley did not line up with the crank or alternator pulleys...so I bought a dual pulley pump. Still having the same issue. Also, the new water pump's pulleys are a lot smaller diameter than the original water pump pulley. What do I do? If pictures would help, I'll get some tomorrow.
Thanks,
Dwight
