Factory equipment?
Factory equipment?
thiswontbetooexpensive
Full Time Jeeper
Madison County, TX
1980 CJ5, Stock and original
258I6, Dana 300, T 176
(poor thing needs a little bit of time and a few kind words)
This has been bothering me: ImageUploadedByTapatalk1355011959.838487.webp
What is supposed to hold this pin in place? This is functional and covered by the shift boot, but...... I'm sure there is a better way.
This won't be too expensive Dear! That's what I keep saying. Over and over again.
What pin are you talking about?
The one that is held in place by the hose clamp. Holds the gear shift to the tranny I'm guessing
If you can't see the picture, I can try and PM it to you.
There is no pin that holds the shifter on it is held in place by the piece on top of the Transmission that goes around the shifter.
There is no pin that holds the shifter on it is held in place by the piece on top of the trans that goes around the shifter.
Thanks mtnwhlr. That's what I was thinking too, just wondering what purpose the hose clamp was serving. I might take it off later when reassembling and see what happens.
Home > Jeep Transmission Parts > Tremec T-176 & T177 Transmission Parts
1980-1986 Jeep CJ5 , CJ7 , and CJ8 Scrambler
The Tremec T-176 Transmission was the optional four-speed Transmission found in 1980 to 1986 Jeep CJ models, often adapted to V8 and V6 power, while the T177 was the J Series versions of this Transmission as supplied with the AMC 258 i6 / 4.2l AMC 258 i6 / 4.2l I6.
Click on Images / Number Item's to Find Parts in Table
T-176 -177-Transmission .gif" data-src="/community/proxy.php?image=http%3A%2F%2Fwww.jeep4x4center.com%2Fjeep-Transmission -parts%2Fimages%2Ft-176-177-Transmission .gif&hash=1fbcd77fc536e1e4b2914cfc55f3b78a" data-lb-sidebar-href="" data-lb-caption-extra-html="" data-single-image="1"> t-176-177-transmission.gif
ItemImageDescriptionYearsCommentsPart
NumberAdd To Cart1 Transmission Gear1980-19868132375$282.99
2 Rear Bearing1955-1986T176 & T177 - Warner 4-Speed Transmission 8132431$34.99
3 Rear Oil Seal1980-19865359457$3.99
4 Cluster Gear1980-1986For T-176 , Teeth (33-26-24-15)8132391$258.99
Cluster Gear1980-1986For T-177, Teeth (34-27-25-15)8132393$304.99
5 Countershaft1980-19868132397$19.99
6 Reverse Idler Shaft1980-19868132398$13.99
7 Reverse Sliding Gear1980-19868132402$42.99
8 Reverse Idler Gear1980-19868132399$133.99
10 Front Bearing Retainer1980-1986For T-177 (3 3/4" O/a)8132372$46.99
11 Main Drive Gear Seal1980-19864 Cyl. - Included In #248133528$2.99
12 Front Bearing1980-1986T176 & 177 4 Speed Transmission 8132426$24.99
13 Main Drive Gear1980-1986For T-176 (20t)8132369$159.99
14 3rd & 4th Synchronizer Assembly1980-19868132376$139.99
15 Low & Reverse Blocking Ring1980-19868124906$9.99
1st, 2nd, 3rd, & 4th Blocking Ring Set1980-19864 Pcs8132378$34.99
1st & 2nd Blocking Ring1980-19868132381$11.99
16 Synchronizer Spring1980-1986Need 2 Per Synch8132377$1.99
17 3rd & 4th Synchronizer Plate1980-19863 Required8124895$0.99
18 1st & 2nd Synchronizer Assembly1980-19868132386$185.99
19 1st & 2nd Synchronizer Plate1980-19863 Required8132387$1.99
20 3rd Gear1980-1986For T-176 (33t)8132379$76.99
3rd Gear1980-1986For T-177 (32t)8132429$90.99
21 2nd Gear1980-1986For T-176 (33t)8132382$94.99
2nd Gear1980-1986For T-177 (32t)8132384$102.99
22 1st Gear1980-19868132389$113.99
23 Mainshaft1980-198611.70" O/a Length8132374$149.99
24 Small Parts Repair Kit1980-1986T17050$29.99
25 Master Small Parts Repair Kit1980-1986Including #24, 16, 17 & 19)T170-50MK$38.99
26 Gasket & Seals Kit1980-1986T170GS$9.99
27 Master Overhaul Kit1980-1986Includes #3, 12, 15, 16, 17, 19, 24, & 26)BK-T170$114.99
28 Shift Knob Insert1980-19863241067$2.99
29 Shift Knob1980-1986Without Shift Pattern Plate3241062$6.99
30 Shift Knob Lock Nut1980-1986Lower4006495$3.99
31 Shifter Boot1980-1986Used With T-176 -t177,
Double Boot5752141$34.99
Transmission Boot1980-19868132422$4.99
32 Housing Cap1980-19868134667$5.99
33 Spring Cap1980-19868132420$2.99
34 Shift Lever1980-1986Lhd (usa)5359835$59.99
35 Shift Lever Spring1980-19868127059$2.99
36 Shift Lever Repair Kit1981-1986SLR176K$11.99
37 Back Up Lamp Switch1980-19865751207$12.99
38 Shift Cover1980-1986Includes Qty 2 of #398134292$174.99
39 Shift Lever Pin1980-19862 Required8132407$3.99
40 Cover Gasket1980-19868132428$1.99
42 Ball Shift Rail1982-19863 Required453593$0.99
43 3rd & 4th Shift Fork1980-19868132412$49.99
44 1st & 2nd Shift Fork1980-19868134429$49.99
45 Shift Rail Interlocking Pin1980-19868132419$2.99
Shift Fork Retainer Pin1982-19868134040$0.99
46 3rd & 4th Shift Fork Lug1980-19868132414$18.99
47 Rocker Arm Reverse Shift1980-19868132815$34.99
49 Reverse Shift Fork1980-19868132413$55.99
50 Bellhousing1980-19868133951$249.99
51 1st & 2nd Shifter Rail1980-19868132408$31.99
52 3rd & 4th Gear Shifter Rail1980-19868132409$31.99
53 Shift Rail Plate1980-1986Front8132415$15.99
54 Shift Rail Plate1980-1986Rear8132416$15.99
55 Transmission Mount1980-19861370910$11.99
56 Stabilizer Mounting Stud1980-19865358879$3.99
57 Stabilizer Bushing1980-1986
#32 is what holds the shifter in the Transmission
is that hose clamp holding #39 (pin) in? if so yes you do need that pin there. somone probably put the wrong pin in. it holds the colar in that holds the shifter in. #32
somone rigged it up. mine has no hose clamp. the pin is pressed in
Thanks. I will investigate further when i get back up there again. Working on rear axle now. Again, thanks for the input!
This housing cap goes over that pin
The collar of this cap keeps the pin from coming out.
Clean it up and use some high strength LocTite.
Got these coming. Should be able to remove the hose clamp and also prevent water from entering the top of the Transmission !:chug:
Thanks for the help!
Got it done yesterday.:chug:
Before
After
Looks WAY more functional! The Metal part actually connects to the pins and the rubber part is what holds the pins in and keeps water out. Nice tight fit:D
Nice :D
I learn something every day.
Nice :D
Me too! I went to order the part you had suggested because I could see it on the diagram. Then, I got to looking at the picture again, then back to the parts diagram and it appeared somthing was missing.... Google Images to the rescue!!!!
Back to the parts diagram, and bingo. 17 or 18 bucks later and wait on FEDEX. Took all of 45 seconds to get these changed/installed. I thought there might have been something missing to repel water, that was the secondary function of the rubber boot I guess!
Thanks to all who provided assistance with this :notworthy:. I will be back again soon with another question...don't worry!!!!!
Life is full of small victories, thats what keeps us wanting to be challenged I reckon:rolleyes:.
