Fluid change in T-150 & Dana 20 - Help??
Not sure what you found there..... Tell us more what is on the label. I will do a search and see what I can read about your gear lube find...
Mfg of product,
address
part number
complete description
where you purchased the gear oil
Well I couldn't sleep tonight so I looked into the lub I found and heres the info
Super S Products Menu Super S Products Engine Oil Gear Oil Hydraulic Oil Chain Oil Marine & Mixing Oil Industrial Oils Synthetic Oils Grease Antifreeze Transmission Fluids Brake Fluid Power Steering Fluid Miscellaneous Products Super Power Degreaser Fluid Treatments Hand Cleaner Chemicals RTV Silicone Aluminum Brightener​
[FONT=Arial, Helvetica, sans-serif]Super S Products/GL-4 & other Gear Oils[/FONT]Manufacturing • Packaging • Global Distribution
Your Guaranty of a Superior Product
Super S
GL-4 Gear Oils 90W and 140W
are multi-service Extreme Pressure gear lubricants manufactured from high quality base stocks and superior additive technology. They are recommended for use in gear boxes, manual transmissions, bearings, gear reducers and many other applications where an API service classification GL-4 gear lubricant is specified.
GL-4 ordering informationproduct
packaging
item #product
packaging
item #90W
6/1 Gal
35 lb
Bulk​
SUS 91-1
SUS 91
SUS 91 Bulk140W
6/1 Gal
35 lb​
SUS 92-1
SUS 92Super S
RED TACK GL-5 85W-140
Hi-Performance Gear Oil
is formulated with high viscosity index, thermally stable base stocks and a highly effective sulphur-phosphorus extreme pressure, antiwear,
anti-scuff, anti-weld additive system.
Hi-Performance gear oil contains “Tackifier” for greater adherence to gears compared to conventional gear oils and is dyed red for ease of leak detection.
Red Tack GL-5 ordering informationproductpackagingitem #85W14035 lb
400 lbSUS 54RT
SUS 55RTSuper S
EP Gear Compound
Super S EP Gear Compound is a premium quality extreme pressure (EP) gear oil formulated with selected additives designed for high levels of protection against gear and bearing wear, rust, oxidation and hydrolytic degradation. Provides excellent performance in high load and/or extreme temperature operations.
Meets the requirements of:
AGMA EP Gear Oils 5EP, 6EP;
U.S. Steel 224 Gear Oils;
MAG Cincinnati, Cincinnati Machine P-59 (ISO 320) and P-74 (ISO 220)
EP Gear Compound ordering informationproductpackagingitem #EP220
EP320 35 lb
400 lb
400 lbSUS 152-5
SUS 152
SUS 153
More Gear Oil...
Engine Oil
Gear Oil
Hydraulic Oil
Chain Oil
Marine & Mixing Oil
Miscellaneous Oils
Synthetic Oil
Grease
Antifreeze
ATF Fluid
Brake Fluid
Chemicals · Treatments
RTV Silicone
Hand Cleaner
Aluminum Brightener
page top · products listSmitty's Supply, Inc.
- one of the leading manufacturers in the world of lubricants and related products.
[FONT=Arial, Helvetica, sans-serif]800.256.7575 [/FONT][FONT=Arial, Helvetica, sans-serif]smittys@smittysinc.net [/FONT]​
40 years of Quality Products • Dependable Service • Competitive Prices​
This is from the man. web sit. THE PRODUCT # ON THE 35 LB 5 GAL bucket I bought has this # on it sus 91 on it so its a 90w gear lub. EP is extreme pressure. WWW.smittysinc.net is the web site.:)
Dear 1986CJ7,
Thanks for the info on the company and GL4 gear lube.
I am in contact with the company and web site and will let you know what I find out...
Thanks again.
direct web link to their GL4 product
http://www.smittysinc.net/GearOil-GL4.htm
Would there be much difference between the 76 FSM and 77? I would like to use it for the my 77 if it is basically the same.
Both 76 and 77 have the prestolite distributor, so yes pretty similar.
$135.00
  67.5%
