fuel injectioning the AMC 304
the alternative with the wiring was more for everyone following the thread I assumed that since you already had yours running you figured it out. I think it was a great write up, someday i will convert mine to efi not sure if i will go with tbi or some sort of a pieced together multi port setup either way thanks for all the great info.
Awesome write up! In fact after searching for days this is the only Jeep AMC 304 write up I have found. I am doing this mod very soon. So hopefully I will remember to do a write up and take many pics.
THANK YOU!!!!!!
Gator, how many pulses does the VSS need to be? I have a 4k pulse vss from my failed TPI project. It is JTR and will work with your D300. I can get it to you for half the price as it is doing me no good.
I also have a new APU1 programmer set up from Moates.net I will no longer be using, it should be the kit you need to eventually do your own programming and chip burning, they go for 330 new but like I said I have no current or future need for the TPI stuff.
TPI and TBI are very related systems and have alot of interchangeable parts.
Thanks Guy, But it looks like in 89 they used the 2k pulse then changed to the 4k in 90. Mine came off an 89 GMC 2500 so I think I need the 2k Vss. After I rebuilt my AMC 304 the ecm makes very few corrections so, I not sure if I will bother reprogramming it. But I will keep you in mind. I will probably find a reason the day after you sell it to someone else.
This thread is great! I just picked up everything from a 1987 full size van for $20.00. :drool:
I just picked up the TBI and Computer this weekend. I am very interested in pictures. Ill be watching!
I've been running this TBI setup for a while now.I actually did this two years ago. If you want pictures pm me. I can always take new ones if I need to.:chug:
This something that you should post so everybody can benefit from it.
Give me a few days and I will put together some pictures.
I like how you mounted the map sensor and ing. module. Don't you have problems with the fuel pump that high? I thought they had to be low so they have more head pressure?:confused:
$45.00
  22.5%
