Engine Fuel squirting out spark plug port
Detheridge
- Gardnerville, NV, USA
- 78 CJ5 304, T18, D20, AMC 20 converted to one pc axle, 4.56 gears, D30 front, 4.56 gears, ARB locker
Hello,Risking derision I must ask, are the spark plugs installed? Or is the gas going past the intake valve/rings to crank case?![]()
Before I would take the carb apart, I would pull it but leave the fuel line on.I rebuilt the carb. I must have done something wrong. I'll pull it and start over. Any ideas what I may have done wrong?
slow down the fuel pressure, buy a regulator, most carbs don't need more than 5 psi. Been there once with my 75 IHC truck too much carb and 9 psi pump, less carb and 5 psi was the cureI rebuilt the carb. I must have done something wrong. I'll pull it and start over. Any ideas what I may have done wrong?
