Fuel Tank Questions
rocmoc
- 1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
I have a '70 CJ5 with the rear fuel tank. The previous owner replaced the original tank (said it was rusted out) with a '78 fuel tank. It was used and is now failing. I have repaired a couple of times but it is time for a NEW replacement. It looks like he bent the corners to get the tank to fit (may not even be installed correctly) and is tight but in the hole. Since I have never seen how the original tank fits I have a couple of questions.
First question, does anyone have the length x width x height of the '70 tank so I can compare.
Second question, I am going with a poly tank, any recommendations?
Thanks,
rocmoc n AZ/Mexico
Thanks,
rocmoc n AZ/Mexico
that is out there. They are in Iowa.
