Funky Coil?
MDJEEPER
- Calvert County, Southern Maryland
- 1986 Jeep CJ
Mostly stock, 258 c.i.d., T-176 tranny, Dana 30 front, AMC 20 rear, Dana 300 t-case, 31x10.50 tires, 2 inch body lift
I am still trying to run down a lack of power issue with my engine. Following the advice of the forum, thus far I have replaced the most basic stuff first...plugs, wires, distributor cap, rotor. However, I have not yet replaced the coil. What are the symptoms of a bad coil?
So far, the work I have done has had little effect on the top-end power of the engine...PLUS if anything, it has made the knocking/pinging under load worse. I just can't figure out why!!??
...And no, I have not yet checked the timing...that's next on the list but I've got to get a working timing light.
Oh, and one more brand new symptom to add...while I was out taking it for a test drive today, it seemed like it wanted to stall a few times...just for a spilt second like the key had been turned off and back on again. This did not occur under load, but just cruising along holding about 40 mph...
