GM 151 Iron Duke, please help
Phoenix, AZ
1981 CJ5- GM 151 "Iron Duke" 4 cyl, Dana C300-15-2 transfer case,
2011 GMC Sierra,
2003 Harley-Davidson FXDX,
Hi guys, forum newb, just picked up an '81 CJ5 with the iron duke, she's spewing oil from this orange plate which doesn't seem to belong here. So what is supposed to go between the fuel pump and oil filter?
I do believe that is the hole for the distributer, but I will admit I am not 100% sure. If it is leaking remove it scrape it clean with a razor and wire brush, apply some good RTV, Permatex Right Stuff or Grey. That will seal it and you should be good to go.
what type of distributor do you have? the pic i found kinda shows a distributor there.
$45.00
  22.5%
