Build Thread Gravy's 79 CJ7 Build
GravyProv1
- Media
- 64
- Hopkinsville, Ky
- 1979 CJ7. 304V8, AMC20 Rear, Dana30 Front, T150, Dana20 xfer. 2.5" ProComp Lift. Fiberglass everything.
Quick update on my build.
1. Finished the steel inserts for the dash / windshield. Made steel inserts with tapped holes and epoxied these permanently into the tub. This should help when we have to disassemble any components from the fiberglass tub.
2. Started wiring the engine compartment. Decided to go ahead and replace the stock distributor, coil, ignition with an HEI. Cuts down on a lot of wiring plus should be better all around performance.
3. Lot of pieces back from powercoater. Hinges, brackets, etc.
4. Finished fiberglass windshield assembly. All new hardware, linkage, etc. Just needs new glass installed.
5. Wheels / tires getting mounted & balanced.
Keep chipping away at it. Whatever date I keep setting to get it done, add another month to it... !!!
Gravy
Gravy
