Great 2100-2150 adapter plate
Jimbos76cj
Full Time Jeeper
Featured
St.Cloud FL
83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!!
Ask me about my head light upgrade harness!!!
That's sweet!
~ Jr
The contact information would be great! I will hopefully be needing one of these in the next few months. I might have found a place for a MC2100 and it came with adapters for an additional charge.:(
This looks to be WAY more functional.
Thanks!:chug:
I used the email in the post.. That will give you a direct line to him. Ill be on eBay later tonite and ill see if i can dig up his contact info on there
I think i've seen his ebay page, he sell carbs too. I have the mr.gasket, but made a pattern with plans to machine out a new out of billet aluminum. I was gonna make mine square with no cut outs on the sides.
The front cut out is needed for that low hanging cover that goes over the power valve. I think the side with the throttle hook up needs to be cut out also for clearance.
i'll look later when I go down to the shop. I have a 2100 on the bench right now, parts came today and I finish it tonight. any idea how thick his adapters are?
IF I get a chance tomorrow i can check.. Id say at least 1/2". instead of FHSC screws he uses regular socket caps.. the hole head is below and there is still 1/8 or so of material below em.
I did a little investigating early today. I'm betting the plates are 3/4". I'm debating o\in attempting one using 1" to reduece chance of warpage even more. I also think I can reduce the front and side reliefs a bit too. I'll have to hunt a piece of 1" aluminum and do some lay out work.
can you make a pic from both side?
Very nice. Thanks for the heads up! :chug:
Hey, I've seen that adapter before. 1st post (I am ehrmannmp from EBay) and I own GRONK Performance. The adapters are about 3/4 thick and mate the hardware exactly. I have an excellent machinist and if the hardware ever changes slightly, he adapts. These will never warp. No need to go thicker. The intake is threaded 5/16-18 and I use 3/4" hardware.
Forgive my noob-ness. But is this what you'd use to run a 2 barrel carb on a 1 barrel intake?
No sir...
You'll want to swap intakes or grab a 2 to 1 conversion
There is a 1-2 adapter used for adapting smaller based 2bbl carbs to 1bbl intakes that mate nicely to the 2-2 adapter I build. The nice part about using a 2 piece adapter is if you ever swap to a 2bbl intake manifold, you have everything needed.
But until swapping to 2 barrel intake, why get the extra adapter?
:confused:
~ Jr
Using a 2 piece 1bbl-2bbl adapter as opposed to a 1 piece adapter is recommended (by be) because it raises the new 2bbl carburetor further away from the single bore intake, adding space for the air/fuel to atonomize. Remember, you are force feeding a large 2bbl carburetor through a single port on the 1bbl intake.. There will be a restriction there. Spacing it out makes for a smoother flow. One thing I also like about the 2 piece adapter combo is it allows you to position the carburetor forwards/backwards or sideways. It gives you more options for connecting your throttle linkage and such.
I quickly read over your post and did not see any questions about that adapter plate.
I picked mine up from GRONK Performance on here and it is fantastic. The price is a little bit more then the cheapo ones that are out there but the quality more then makes up for it. Ive had 3 friend swap from thier cheapo adapters with poor running jeeps to Gronks adapter and the idle smoothed out and got rid of the flat spots on acceleration.
http://www.jeep-cj.com/forums/f2/great-2100-2150-adapter-plate-18082//
heres my post about my adapter.
As far as rebuilding goes to me the most difficult thing is setting the float height right.
Heres a file on rebuilding it.. make sure to take note of the part about blocking of the choke vacuum port
http://www.therangerstation.com/tech_library/pdf_documents/motorcraft_2150_carb.pdf
