Hardtop needs some TLC..
Project86
Old Time Jeeper
Tx Gulf Coast
1986 CJ 7 Blue
2004 Chevy LWB CC,
2012 Corvette Grand Sport
1986 CJ 7 Red Garnet
1978 CJ 7 Kinda Orangish
My hardtop is less than sightly. So I want to do one of two things, either buff,sand,strip,etc back to or close to the original look or spray bedliner on it. I'd like to get back to the original look. Problem is the PO's have painted over the top. I got schooled today in sandblasting techniques and was told DO NOT sandblast fiberglass, even with sugar sand. The top has been weathering and it's now a combination of the original look(although weathered) and places of PO paint. Pictures can be seen on the build thread. So what does the jeep brain trust :notworthy: recommend? Die grinder with a scotchbrite pad? Electric grinder with a stripper wheel of some kind? Solvent? I guess the biggest question is can a hardtop be restored to it's original look(more or less) or am I going down a pointless path? Either way I want to keep the top and somehow make it look decent. So all ideas are welcomed. Ya'll's turn to speak.
If the existing finishes are solid and well adhered to, what about spraying over it ? That would be the path of least resistance. Are you going for daily driver or show,... ? Does the top have scratches down into the glass ?
If you going down to the glass, given the item itself, Id probably go chemical strip/scrape, followed with a pressure washer (hot water if you can access one) or Id finish on top if the substrates below are solid. What about a different top ? Ive junked 3 Cj hard tops in recent years because I could not give them away, have you looked around for a different one ?
