Hays pressure plate
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Yep, it's a 10 spline 1 1/16" shaft. Part of the sticking point is that CJ's came with 10.4" clutches (most have 1 1/8" shafts) and I'm being greedy wanting to use the holes drilled in the fly wheel for an 11" clutch. Fewer and fewer clutch manufacturers off their parts separately. Center Force is one of them. Nice clutch .... nice expensive clutch .... a clutch built to perform at higher RPM's than most jeepers will ever see. For that reason alone I've ruled out the Center Force for my intended purposes.
