Header bolts and gaskets
Purple77CJ7
Full Time Jeeper
Loveland, Colorado
1977 CJ 7; Amc 401 .30 over, Howell TBI, modified Dana 20 with Terra Low gears and twin sticks, NV 4500 5-speed, modified Dana 30 and Amc 20 both with 4.56 gears (narrow track), ARB air lockers front and rear, SSBC rear disc brake conversion, MICO Brake park brake, Navaho brake booster/ master cylinder, PowerTank CO2 tank.
I use Stage 8 with modification as well.
I also had problems with header gasket leakage.
I went to these:
Percy's High Performance 68044 - Percy's XX Carbon Exhaust Header Gaskets - Overview - SummitRacing.com
So far they have not failed me yet, and I think the main reason the gaskets were so prone to failure was the bolts were backing off and allowing it to shift, swell and shrink etc.
I think The header-bolts may have been the main fix, but these gaskets are very thick, and seem to seal excellently.
Thanks Purple77CJ7 for the good info too :cool:
~ JR
I went to these:
~ JR
That is a good point with the loose bolts. And those gaskets that are made of better material,too.
Question:
Using stock iron manifolds, would it be better to use bolts or studs/nuts?
I already bought grade 8 bolts, but holding those darn manifolds in place is a b..ch while trying to thread a few bolts. Sure would seem easier to hang them on a set of studs and seal the deal with a nut/lockwasher...
I would think as long as you got grade 5 or 8 studs that it would work. I think using studs, I would never seize the studs. Down the road they could be tough getting back out. I would also use lock nuts (not nylocks). Years ago on old equipment ( tractors and trucks) that was how exhaust manifolds were attached. I think to cut down on production costs the manufacturers used bolts instead. One piece compared to two or three pieces. My thoughts.
You might have to go to some place like Fastenal to see if they have shoulder bolts. Or I have seen some steel sleeves at Ace Hardware that you could cut and make your own. Other wise I'm not sure if it's needed.
thanks purple...
I actually just took down the post because I figured I'm just overthinking this....
Too much time on my hands some days!!
thanks again
brian
