Electrical Headlight fuse blows
Good deal. I am surprised you had issues with the painless harness. Other than being time consuming I found it pretty straightforward except for wiring my heater switch because the harness is not setup for a 3 position switch. The painless tech talked me through wiring it up as a simple on/off switch though. Their support is top notch in my experience and I did mine in the middle of the spring lockdowns.
Sent from my SM-A405FN using Tapatalk
It wasn't an issue with the harness...there was a third loose wire coming out of the connector on my parking light and I wasn't paying attention.
I had Painless on the phone while I was checking continuity in case I had any questions. Turned out to be a dumb mistake and simple fix. The tech on the phone was very patient and helpful. He was just happy that I knew how to operate a multimeter.
Sent from my Pixel 2 using Tapatalk
Electrical Fuse panel
