Wiring Headlight issues
Petescj
Member
Lifetime Supporter
Featured
PA
1982 CJ-7 258 / T-18 / Dana 300 31 in All Terrains.
1978 CJ-7 304 / TH 400 / Quadratrac 32 in Mud Terrains
The CJ uses a 3-wire dimmer switch mounted on the floor. So the black harness in your first pic is the stock setup. Not sure why your harness has 4 wires or what that black wrapped "bundle" is in that pic. The dimmer switch itself has 3 pins to connect into that black connector. There is no ground connection on the dimmer switch. So no concern with connecting the housing of the switch to the floorboard for any grounding need. When you turn on the headlights using the dash switch, the +12V goes from that switch to the center pin in the dimmer switch connector. The dimmer switch then routes that voltage out the left or the right pins (depending on low or high beam selection) to the headlights. So all you're doing is switching the +12V through that dimmer switch. The full current draw of your headlights is going through that switch, the connector, and the associated harness. For the most part, stock headlights are 35 watts for low beam and 55 watts for high beam. So that's 2.92 or 3 amps for low beams and 4.58 or 5 amps for high beams (times two since two lights wired together). So either 6 or 10 amps which could challenge old wires, connectors, etc. And if the headlights have been changed to something not stock (halogen or something), then the current draw could be even higher. So burning this switch and/or the connector is quite common in old CJs.
The answer is to re-route that power through an alternate path instead of the stock harness/switch. You can buy some kits to do this, or you can do this for about $10 and some scrap wire. Get two 12V automotive relays mounted under the hood somewhere and re-route some wiring. You'll get brighter and more reliable headlights and stop burning through dimmer switches.
Of course you need to figure out what's up with your extra wires in your harness that aren't stock.
Here's a thread with details on how to do it in a stock setup: Headlight Wiring Mod
The CJ uses a 3-wire dimmer switch mounted on the floor. So the black harness in your first pic is the stock setup. Not sure why your harness has 4 wires or what that black wrapped "bundle" is in that pic. The dimmer switch itself has 3 pins to connect into that black connector. There is no ground connection on the dimmer switch. So no concern with connecting the housing of the switch to the floorboard for any grounding need. When you turn on the headlights using the dash switch, the +12V goes from that switch to the center pin in the dimmer switch connector. The dimmer switch then routes that voltage out the left or the right pins (depending on low or high beam selection) to the headlights. So all you're doing is switching the +12V through that dimmer switch. The full current draw of your headlights is going through that switch, the connector, and the associated harness. For the most part, stock headlights are 35 watts for low beam and 55 watts for high beam. So that's 2.92 or 3 amps for low beams and 4.58 or 5 amps for high beams (times two since two lights wired together). So either 6 or 10 amps which but could challenge old wires, connectors, etc. And if the headlights have been changed to something not stock (halogen or something), then the current draw could be even higher. So burning this switch and/or the connector is quite common in old CJs.
Ok I'll work with the 3 wire harness then. I did have a harness with relays on my Virginia Jeep and the lights were much brighter. Only thing that's confusing me now is the whole 30 seconds of working than nothing. Hopefully that won't be the case this time around.
That's weird that the high-beam wires are melting. I've also got a AMC 258 i6 / 4.2l with the headers running under the driver side floor pan, and I've never had any problems. Maybe it shorted out?
I remember JeepHammers posts (in another forum) where he dedicated an outstanding thread about Jeep wiring it's worth a read!
(Link)-> BASIC WIRING 101, Getting You Started! -<
Basically stock headlights are grounded to fenders and this does not provide sufficient ground for higher amp accessories. Myself I ripped a Grounding Bus Bar from an old household switch panel, cleaned it up, and ran 6 ga. wire from my negative battery terminal then ran all of my grounds to it. Thereafter all the stuff that was failing to varying degrees began working again.
$45.00
  22.5%
