Heater hoses Question
You have two hoses that go to the heater take one off and the other one remove from it from the heater and hook it to where you removed the first hose at the motor.
It seems that somewhere in the part I've heard that the engine intake uses the return water to regulate intake heat. It's a very dim. memory, I could be wrong.
On some of the 4.2 engines they run the return heater hose through the intake manifold to heat the gasses in colder weather. I believe the 304 doesn't.
So just run a hose from the water pump to the intake and all will be good.
Would it make any difference in the coolant temperature, being that the hose going from the water pump to the back of the intake is a shorter route than the original route thru the heater....that being longer ?
Another Question ! I have 73 cj5 with a 304 V8. The heater is pretty much totally shot, which is not an issue because I will never use it anyway. I had planned on taking the whole unit out from under the dash but what do I do with the heater hoses ????????????
Please plug the dang holes and be done with it.The heater hose has absolutley nothing to do with the engine cooling other than the cooling from the heater core.You can live with out that.Most systems have a heat control valve that shuts off the flow of coolant to the heater core when it is not in use.Really.mike s.
