Help! How to remove leaky selector shaft on th400
76cj7chick
Old Time Jeeper
WA
1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Bump...... Anyone?
Would I have to drop the pan in order to remove/reseal the shifter shaft (is that the right name for it?
PLEASE anyone?
By the way, i noticed this is in the wrong threading, so i posted in cj build...
you might be able to take the linkage off the shaft and get the seal out that way, but its easier to drop the pan.
That is some pretty nice "lever" work there... :D have you got it fixed yet?
I know the po really did a bang up job on the cj...
Its not fixed yet... :(
I ordered a lokar gm lever kit and just received the lokar Transmission mounted backup switch... Today I ordered a shaft seal remover tool from Napa...
I just need to find the seal now... Anyone know a good part # and where to find one?
Thanks for your suggestions and comments...
I hope to buy a deep tranny pan soon but would like to warm up the tranny fluid before I drain it and put fresh oil in... especially, since I don't know when it was drained last... :)
However, before I can do that, I have to finish installing the wiring harness... I am almost finished but have a few challenges...
Nice work, looks good! I just threw mine back in, didn't really have time to do any more..
Thanks for your kind comment... I know what you mean though... About not having enough time.. I love my Jeep but it is taking lots of time and money (and research) in getting it together... :( On the bright side, I am learning a great deal about him.. :)
Wish I could help, it's kinda one of those things I've never seen go bad.. Have you tried looking at, or even have a Chilton's or Haynes repair manual?? I usually get on line, type in my problem and then check everything that comes up to see if it helps...
P.S. I don't see how it could fall into the tranny, most seals run up against a machined lip... just an observation
Hmmm.. It appears something is IN the shaft hole -- besides the shaft lever :O So I thought it might be the seal... Or is that silly?
Hmm....
I think you're talking about the main shaft seal, right?
I'm referring to the Shifter Shaft Seal... :o
But thanks for your response.. :)
Could be what you're looking for.. I'm sure you have the new seal, does it have any resemblance of a seal left? May be nothing but a metal ring left.. The directions for the seal remover reads ...
Removes and installs shift selector shaft Transmission seal without draining fluid Works on G.M. Transmissions. Instructions 1 Disconnect Shift Linkage 2 Unscrew Remover Screw a Few Turns And Place Remover Over Selector shaft. 3. Push And Turn Remover Threads Into Seal 4.Turn Remover Screw Inward To Pull Seal. To Install New Seal 1. Put new Seal Over Selector Shaft 2. Put Installer Over selector shaft And gently Tap seal Into Place 3 Reconnect shift Linkage.
Niedhogg May be nothing but a metal ring left.." I think you may be right.. :eek: (It may just have a metal ring.--but it still leaks.. is that right?.) The tranny seal I got from Napa fits in the shifter shaft hole but wants to slide in a ways.. Is that normal on 400s? What do you think? Here is pic. I dropped the tranny pan to take a look inside and it looks real clean. Could it have been rebuilt? Plus in one of the pics (I don't know the name of the part) there is white stamped "16J". Any one know what that means? Also I have found on the (valve body?) an embossed number : 8626577A. Any/all help is ALWAYS appreciated:notworthy: ps. In the mean time I ordered a new finned deep tranny pan (same depth as mine but with a drain plug-- I got wayyyyyyy to oily when I drained the ATF and the plug will be warmly welcomed.) and a new filter pickup extender.. :drool:[/QUOTE said:
The drain plug will be very nice, I'll be getting one of those pans someday..
Have you tried using the seal removal tool yet to see if it will remove anything? Hrd to see in the pic, but it almost looks like there's no seal at all.
Hi Niedhogg, Yes, I tried the shaft seal tool extractor but it doesn't attach to anything... So, you may be right about not having any seal in the hole! :dunno:
:ty: for your assistance! :rock:
Now I am just waiting for the pan and a new filter extension then I can put him back together. :grinjeep:
