Help jeep was half sunk!(long post)
playnsnookie
southwest florida
83 CJ8 258
While out at our hunting camp last weekend my scrambler took a nose dive into a deep water hole. I have changed all the fluids ( front rear diffs, tranny, Transfer Case and engine) the starter was submerged and I replaced it with a new one. I installed the new starter and turned the jeep's AMC 258 i6 / 4.2l over. The starter was Very noisy and finally did turn over. The starter continued to engage and the engine kept running even when the key was turned off. I thought maybe the solenoid was stuck open so I replace it. I repeated the above process this time when i turn the key nothing happens at first, but then it struggles to fire. I tested the starting side of the solenoid and it have 12v. Bad Coil???
While out at our hunting camp last weekend my scrambler took a nose dive into a deep water hole. I have changed all the fluids ( front rear diffs, tranny, transfer case and engine) the starter was submerged and I replaced it with a new one. I installed the new starter and turned the jeep's 258 over. The starter was Very noisy and finally did turn over. The starter continued to engage and the engine kept running even when the key was turned off. I thought maybe the solenoid was stuck open so I replace it. I repeated the above process this time when i turn the key nothing happens at first, but then it struggles to fire. I tested the starting side of the solenoid and it have 12v. Bad Coil???
as in "bad coil" on the solenoid, yes , could happen.
Put a charger on the battery over night and see if that helps.
I would love to see pics on that adventure, although I have seen a lot of that stuff. It does seem that you have acquired a set of problems though, possibly starting with starter gear mesh issues. Even possibly a bad starter to begin with,. Along with testing for a bad relay and possibly other electrical componets.
$45.00
  22.5%
