holley projection
jeepboy45
Old Time Jeeper
- Altamonte Springs, Florida
- 1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
Hello fellow Jeepers....
I've got a couple of questions for those who might have experience in this area.. I've got a newly rebuilt 360, and I'm going to install a used Holley Projection system.
The setup comes with an electric fuel pump. Directions are specific about mounting it at or below the lowest part of the fuel tank. Years ago I installed a 20 gallon factory poly tank from a later model CJ. There is no part of the frame that sits lower than the bottom of the tank. A Holley tech told me that I needed to put it lower, OR get a "sucker" type of pump instead of using the gravity fed Holley..
Has anyone put on a Holley or Howell setup and used the gravity fed pump NOT below the tank???
I was toying with the idea of an electric pump mounted in the tank. Recently I've changed a couple of GM pumps in my older van and Tahoe. I really like the idea of a factory pump for reliability, and would like to be able to have one mounted directly in the tank like GM (and I'm sure Ford) does.
Does anyone have any imput on retrofitting a stock Jeep tank to accept a pump from some other applicaton.
I modified the Holley wiring harness and it is all soldered in. Now I just need to finalize mounting the pump, and I'm ready to go..
thanks very much for any imput.
Brian
Brian
Havent got around to mounting the tank, I have heard that I might have to move one of the support bars by 1" Also if you look at the Howell kit which I have installed before they sell you a frame mounted Walbro pump which is pretty easy to install on the frame rail in front of the gas tank
