Holley vacuum question.
jeremy5780
I have a 1985 CJ7 256 straight 6 with a holley 390cfm carb on it. the carb has 3 vacuum ports coming off it. The timed spark vacuum which is going to the distributor cap. The pcv which is going to the pcv valve and last there is a full manifold vacuum this is the one that is not hooked up on my jeep. does it go to something or are you guys just capping it off?
