homemade hardtop?
homemade hardtop?
drivert51
Southern Illinois
1972 CJ5, 304, 3 speed
Anyone make/seen a homemade hardtop? Thinking of making one for my CJ5 . Square tubing and light sheet metal. Removable side and rear windows would be great.
As hard as it is to find a hardtop for a CJ5 if you make one people would like it could make you rich.
I understand the center of gravity thing, thanks for pointing that out. I really want a safari (as in African safari) look. Maybe sheet metal for the roof with roll up canvas sides and back.
Sounds interesting. I don't know if I have any advice for you but I'd love to see it done. You'll have to post it.
Wow, a metal roof and canvas sides would be very cool idea. I personally like having a bikini top or just my windows from my supertop removed so that idea intrigues me. I may start brainstorming and try to help you bring up some more ideas for fabbing this up.
I had not seen that site when I had A 5 I could not find a hardtop that is one of the reasons why I now own A 7. winters can be really cold here and the factory soft tops just plain sucked. All the rust holes didn't help either:laugh:
Never saw a homemade hardtop that didn't look like a piece of :dung:.
Used hardtops are out there -craigslist or wanted to buy. Good luck.
I never thought the hard top was warmer than the soft top just more secure. the soft top was actually quieter.:D
I don't know how you can say that I have had both and the soft top is a lot louder and the hardtop is a lot warmer. :censored:
Did you have a hard top on a CJ5 ?? :wtf:
Ok, design (and maybe some fabrication) for the top starts this weekend. Also going to convert the points ignition to electronic. Anyone use Mallory conversion units before? Also, should I worry about rebuilding the old carb or replace it? What would be a good (but reasonably unexpensive) upgrade?
ps thanks for all the input
Post some pics
Also going to convert the points ignition to electronic. Anyone use Mallory conversion units before? Also, should I worry about rebuilding the old carb or replace it? What would be a good (but reasonably inexpensive) upgrade?
You should make new threads for these mods instead of blending it in with a thread on the hardtop.
But as long as you brought it up. I would keep the OEM carb unless it give you trouble.
Ignition: I would do the Team Rush upgrade. http://www.jeep-cj.com/forums/f2/teamrush-ignition-upgrade-11416/
