how much Hp needed for 42's?
panamacj5
- panama city, Panama
- cj5 v8 302 tranny t-19 dana300 dana30/amc20,
4runner 91 2.8 diesel
I wouldn't go anything less than 5:13's. It takes a lot to turn 42's and the power output you are suggesting from your engine will cause a lot of clutch-riding...which will lead to clutch failure. you need torque from gear reduction or a lot of power to reduce the wear on components.
With the T19, you will have a very good low ratio....this will help a lot and the D300 can be further geared down with a 4:1 conversion. given that setup, I would hesitate to run anything numerically lower then 4:88's...that will still be pushing it.
Consider STRONGLY upgrading the D300 output.....it is a weak area with large tires and a lot of power/torque.
Not all Ford T-19's had the 6:32 low gear in fact they are quite rare. Most of the T-19s had I believe a 5.00 low gear.![]()
I don't know about extremely rare but to assume that all T19's are the 6.32 may lead you to a surprise after you buy it.
RARE? Call it what you want, but I looked around on a casual basis for several years at truck wrecking yards all over and never found one, of course most of the wreckers had no Idea how to check except for year , version & motor. If you go on the Ford web site the 6.32 version was only available for 3 years and only with the 460 motor and only in 4 wheel drive. Does that make it Rare or hard to find?
And Yes , IH had version of the Borg Warner T-19 but the case they used unlike the Ford version would be hard to swap into a bell housing because of the lack of ears.
I went with the BW T-18 Ford version , much easier to find and get parts.
You can call Novak if you question this.
The only T19 with 6-1 ratio first was used in IH, usually the Scout but it has been known to turn up in the truck also.
T19 with the 5-1 ratio is pretty common in the Ford Bronco and F150 behind the 302 and I6 in the mid 80's.
The T19 in the 4-1 ratio pretty much fell in everything else.
I have been down this road many times and like the T19, I have put them in a few CJ's with the 5-1 ratio.
A T19 (5-1) with the D300 (4-1) and 4.10 gears running 42 inch rubber will have a crawl speed to the ground of 98 feet per min at 750 rpm.83.80 crawl ratio.
Low crawl is more than low enough!
However for highway ; 60 mph in 4th gear you will running 1968 rpm. Its doable but will probably suck on the hills.
4.56's would be 2189 rpm
4.88's would be 2342 rpm.
Keep in mind thow, that those 42's are going to have some attitude on the highway and you may find you don't really want to go 60+ with her.
I said " I don't know about..." I never told anyone they were wrong????
BTW: if the OP stated he did a 4:1 conversion on the Dana 300 I missed it. If we are suggesting other mods why not a Stak 4 spd or an Atlas or an...? A 5:1 T19 with factory Dana 300 with 4.10's and 42's would give you a 54.68 crawl ratio in place of that 83.80. 54.68 is still decent. If you question that an unmodified Dana 300 did not have a 4:1 low gear feel free to call Novak...![]()
i guess i will stay with 4.56 to save some money ...we dont do rock crawling here in panama or at least most people dont ... i will put a link so you can have an idea of our trails, thanks everybody for posting
Panama,
We all would like to hear whether or not your T-19 has the 6:32 gears out not?
I for one don't see or hear of them often with that low gearing.
I would try out what you have and if you need to change gears in the future there are a lot of options..........
