Idea of Trans Cost Rebuild
RQCinLHT
Liberty Hill, TX
1983 CJ5 - 4.2L
Good Morning,
I'm finally getting some money to get back to working on my jeep again. I'd pulled the motor about 6 weeks ago, and I found that the Transmission bell housing had cracked, causing the problem I was having with the starter barely contacting the ring gear. I also found that the input shaft has a lot of slop too, probably wasn't too good on it with the engine & trans getting misaligned when that crack happened. I'm going to get the trans rebuilt, and just wondering what I can expect. I'd deliver it to the shop, no need for them to pull it. It's the 4-speed (T-4 ?) trans. I'm also wondering if it's possible for it to be rebuilt as a 5-speed? I've just started my research, but sounds like the case is the same for the T4 and T-5 . It'd be nice to have an Overdrive for the highway driving.
Have you checked locally (CL) for a used one? I sold mine quickly for $375. I know some places that build/sell transmissions and parts kits (Novak for one) that wont touch a T-4 /5. Depending on what hard parts yours need's replaced, I would think you'd be looking at least $1500 for a shop to do it
The T-4 /T-5 cases are darned near the same, but different. There is an extra hump along the side of the T5 Transmission .
I hope you have a T4, I think it's out of the SR4 date range. None of them are more than adequate. If it's an SR4 it's not worth rebuilding. I had mine rebuilt 3 times in less than a month. The transmission shop finally refused to fix it and gave me my money back. Unfortunately it was worse after the "repair" than it was before. Therefore I will NEVER have anything good to say about an SR4 ..... and it was taken care of, no it wasn't abused.
Post some pictures so we know for sure just what tranny you have.
How about a right and left profile shots of the tranny?
Tag number indicates T-177.
